My Mothers Frigidaire dishwater is getting to water;
- The first thing I checked was the shutoff valve under the sink and its on.
- Next I thought it might be the water inlet valve, so when I turned on the dishwasher I noticed that the brass elbow that connects the water supply line to the inlet valve is cold and the 1/4" water supply line is cold as well. I checked this theory out with my dishwasher and when I turn on my dishwasher the brass elbow get REALLY HOT!! and the 1/4" supply line is fairly warm as well.
So is it possible that this 1/4" water supply line can get plugged up somewhere between the shutoff valve and the inlet valve?? Has anyone else had a plug in the supply line?
Ray
