Looking for troubleshooting advice.......dishwasher has an intermittent power fault. Display does not come on some of the time.....then does. Stops in middle of cycle, than starts, then stops again. Pulled it out and checked the control module, looks OK, no burnt areas. Checked all the wires down below and the connections etc and also removed the door panel and checked all that wiring. Looking for suggestions before I call a repair man
