I've got a Frigidaire microwave (Model FMV156DCB) that has a interior bulb that has just burned out. I see there is a cardboard type cover that's located on the right interior wall of the unit. I removed it thinking that's where the bulb was located, but the hole behind this cover is so small, I can't get my hand inside and even if I could, I doubt I could maneuver it so that I could unscrew and remove the bulb.
Is the bulb in fact located in that area and if so, is there another way to access it? If not, can anyone tell me where it's located so I can get it replaced?
Thanks in advance for any assistance with this.
Warren
