Gcaugh
#1 Posted : Thursday, May 30, 2013 3:57:33 PM(UTC)
Gcaugh
After we set it to self clean and it completed the cleaning cycle now it won't hear up at all. I checked the Electrical panel and there is a separate circuit for the oven, two 30amp breakers which were not tripped, I went ahead and tripped them and re-set the breakers but the oven still won't heat. everything else clock interior light ect is working.. but neither the broiler or the bake elements will get hot.. Suggestion?/ could it be the thermal over load of the elements?
#2 Posted : Friday, May 31, 2013 4:25:02 AM(UTC)
Parts for Whirlpool RBS245PRB00 Wall Oven - AppliancePartsPros.com
Yes odds are that it is the thermal overload.
Also would be a good idea to check your oven sensor especially if the oven seems to run hot when you use it re: you either use a lower temperature or shorter time when baking.
It could be that the oven needs calibrating, see the tech sheet.
File Attachment(s):
RBS245.pdf (384kb) downloaded 5 time(s).
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Thermadore PRG304GH oven not heating (Oven Repair (including Ranges and Cooktops))
by Guest 12/15/2022 6:58:50 AM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
Belarus Guest 10/14/2022 12:50:23 PM(UTC)
Bottom oven not heating (Oven Repair (including Ranges and Cooktops))
by Castelle 1/21/2022 6:17:26 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
Frigidaire GLEF378CBD - oven not heating (Oven Repair (including Ranges and Cooktops))
by canooten 3/20/2020 11:24:19 AM(UTC)
by deanowhitney 7/11/2018 11:22:38 AM(UTC)
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 4/4/2018 5:59:05 PM(UTC)
Oven not heating when using convection (Oven Repair (including Ranges and Cooktops))
by ebonyclose 3/11/2018 7:37:25 PM(UTC)
Frigidaire Double Oven - Lower Oven not heating - Clicking (Oven Repair (including Ranges and Cooktops))
by RentAHubby 10/3/2017 8:42:44 PM(UTC)
Whirlpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by proto8432 7/15/2017 10:07:03 AM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
Upper oven not heating, lower over works properly (Oven Repair (including Ranges and Cooktops))
by Greg2cycle 11/5/2016 9:50:34 AM(UTC)
Oven not heating properly (Oven Repair (including Ranges and Cooktops))
by Rentalmom5 9/14/2016 6:24:38 AM(UTC)
Whirpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by cdfrerichs01 8/7/2016 10:55:06 AM(UTC)
