Mr.Cha
#1 Posted : Friday, April 5, 2013 3:00:28 PM(UTC)
Mr.Cha
I have a maytag for about 2 years now, my washer will fill with water but won't agitate, spin, or drain i bought a new lid switch and replace it with the old one and its still doing the same, and when i turn it on for a little bit after the water fills i can smell this burn like rubber burn or electric burn, please help..
sidfink43
#2 Posted : Monday, April 8, 2013 4:24:34 PM(UTC)
sidfink43
I am thinking that there is something jammed in the pump, so check that out. If the pump is ok then the coupling may be broken and jamming things.
Here is the part along with a video that will show you how to get into the machine.
Part number: AP3961972
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
Maytag Washer shaking - badly (Washer Repair)
by chansman94 1/12/2023 6:47:51 AM(UTC)
Maytag Washer Unbalanced After Tub Bearing & Seal Replacement (Washer Repair)
by Guest 12/26/2022 7:20:26 PM(UTC)
Maytag washer agitates instead of spins (Washer Repair)
by Guest 12/10/2022 11:31:05 AM(UTC)
The pulley on the bottom of my Maytag washer motor has broken. (Washer Repair)
by Guest 9/18/2022 9:05:55 AM(UTC)
