mel4230
#1 Posted : Thursday, February 7, 2013 2:36:23 PM(UTC)
mel4230
side by side top mounted compressor and condensor. opening on the right side when faceing the doors. using a long condensor brush is only cleaning about half even when using the vacuum with a clevice tool. also i can not
get to the fan to clean the blades. is there a better way then taking the complete cover off? also can i use a loose furnace filter at the conrensor opening? thanks for taking the time to help.:confused:
#2 Posted : Friday, February 8, 2013 3:05:49 AM(UTC)
Check model #
