MODEL# PGR366 ZS /01
Per the directions to configure the board, the oven falls into one of these categories:
PRO-27 PG PRO-27 PD-PDR PRO-24 P PRO-24 DP
I've talked with Thermador 3 times— they say only the servicers have this information. Hard to believe.
Does anyone have this info? Thanks.
Groups: APP Team
Hi.
If it's 27"- then PRO-27 PG.
Simon.
Nope. The PGR366 ZS /01 is a 36" Oddly, per the board config instructions, the 36" DOES fall into one of these categories: PRO-27 PG PRO-27 PD-PDR PRO-24 P PRO-24 DP
I see. When you don't have the answer, you don't reply. Got it.
If you can post the part number of the board and the instructions, it might help to help you better.
