jackbquick97
#1 Posted : Friday, August 21, 2009 10:50:20 AM(UTC)
jackbquick97
Neither my oven (baking portion) nor the broiler works. I'm thinking its either the spark module or the gas valve.When turned on the oven clicks twice but no gas is released and there's no spark.
jackbquick97
#2 Posted : Friday, August 21, 2009 10:53:00 AM(UTC)
jackbquick97
#3 Posted : Friday, August 21, 2009 1:13:06 PM(UTC)
The first thing I would do is check the gas valve/regulator (#13 on the diagram). You can use the instructions from one of our previous posts: http://forum.appliancepartspros...l-oven-wont-heat-up.html
- The gas valve/regulator Part number: AP3886450
jackbquick97
#4 Posted : Friday, August 21, 2009 10:07:26 PM(UTC)
jackbquick97
I followed your guidance from below and the previous posts. There was no continuity on the top and the bottom had 205 ohms. I ordered the valve and hopefully it will get here by Wed of next week. Thanks for your fast professional reply!!!!!!!!! I'll let you know how the fix turns out.
Oven/Broiler Inop but stovetop and dispaly works (Oven Repair (including Ranges and Cooktops))
by eleatherman 2/7/2011 1:09:01 PM(UTC)
