Discuss
Won't Heat after Self-Cleaning Cycle
 in
Following a self-cleaning cycle, the oven doesn't heat. Neither the top or bottom element heats up at all. The electronic
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Won't Heat after Self-Cleaning Cycle
  #1 (permalink)
Old 06-07-2010, 10:50 AM
Junior Member
JolieBlonde is on a distinguished road
Default Won't Heat after Self-Cleaning Cycle
Model Number: RBS275PDQ11   Brand: Whirlpool   Age: 5 - 10 years
Following a self-cleaning cycle, the oven doesn't heat. Neither the top or bottom element heats up at all. The electronic display, timer, oven light, etc., all work just fine. Is there a fix I can do myself? Thanks!
Ads By Google
Related Models
Whirlpool RBS275PDQ11
Whirlpool RBS275PDQ12
Whirlpool RBS275PDQ13
Whirlpool RBS275PDQ14
Whirlpool RBS275PDQ16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDQ17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDQ2
Whirlpool RBS275PDQ4
Whirlpool RBS275PDQ6
Whirlpool RBS275PDQ8
Whirlpool RBS275PDS12
Whirlpool RBS275PDS14
Whirlpool RBS275PDS16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDS17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDT10
Whirlpool RBS275PDT11
Whirlpool RBS275PDT12
Whirlpool RBS275PDT13
Whirlpool RBS275PDT14
Whirlpool RBS275PDT16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDT17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRB00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRQ00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRS00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRT00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS277PDB1
Whirlpool RBS277PDB2
Whirlpool RBS277PDB4
Whirlpool RBS277PDQ1
Whirlpool RBS277PDQ2
Whirlpool RBS277PDQ4
Whirlpool RBS305PDB1
Whirlpool RBS305PDB10
Whirlpool RBS305PDB11
Whirlpool RBS305PDB12
Whirlpool RBS305PDB13
Whirlpool RBS305PDB14
Whirlpool RBS305PDB16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDB17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDB2
Whirlpool RBS305PDB4
Whirlpool RBS305PDB6
Whirlpool RBS305PDB8
Whirlpool RBS305PDB9
Whirlpool RBS305PDQ1
Whirlpool RBS305PDQ10
Whirlpool RBS305PDQ11
Whirlpool RBS305PDQ12
Whirlpool RBS305PDQ13
Whirlpool RBS305PDQ14
Whirlpool RBS305PDQ16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ2
Whirlpool RBS305PDQ4
Whirlpool RBS305PDQ6
Whirlpool RBS305PDQ8
Whirlpool RBS305PDQ9
Whirlpool RBS305PDS12
Whirlpool RBS305PDS14
Whirlpool RBS305PDS16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDS17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT10
Whirlpool RBS305PDT11
Whirlpool RBS305PDT12
Whirlpool RBS305PDT13
Whirlpool RBS305PDT14
Whirlpool RBS305PDT16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT8
Whirlpool RBS305PDT9
Whirlpool RBS305PDZ1
Whirlpool RBS305PDZ10
Whirlpool RBS305PDZ2
Whirlpool RBS305PDZ4
Whirlpool RBS305PDZ6
Whirlpool RBS305PDZ8
Whirlpool RBS305PDZ9
Whirlpool RBS305PRB00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRQ00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRS00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRT00 30" Built - in Electric Oven Self Clean
Whirlpool RBS307PDB1
Whirlpool RBS307PDB2
Whirlpool RBS307PDB4
Whirlpool RBS307PDQ1
Whirlpool RBS307PDQ2
Whirlpool RBS307PDQ4
Frigidaire RBSF117E1 BLACK Frg(v3) / Electric Cooktops and Control Box
Frigidaire RBSF117EL1 Frg(v2) / Electric Cooktops and Control Box
Frigidaire RBSF117EW1 Frg(v1) / Electric Cooktops and Control Box
Frigidaire RBSF129EL0 Frg(v4) / Electric Range
Frigidaire RBSF129EW0 Frg(v3) / Electric Range
Frigidaire RBUGCF95ED Frg(v6) / Wall Oven
Frigidaire RBUGCF95EK Frg(v7) / Wall Oven
Frigidaire RBUGCF95EW Frg(v5) / Wall Oven
Amana RC-10B Commercial Microwaves
Amana RC-10B-DD Commercial Microwaves
Amana RC-10B-PB Commercial Microwaves
Amana RC-10D Commercial Microwaves
Amana RC-10PB Commercial Microwaves
Amana RC-10S Commercial Microwaves
Amana RC-10SD Commercial Microwaves
Amana RC-10SE Commercial Microwaves
Amana RC-14 Commercial Microwaves
  #2 (permalink)
Old 06-09-2010, 06:06 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL RBS275PDQ11 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/w...%204451884.pdf
First tru flipping your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
If that does nothing it would be a good idea to check the voltage (240 volts) at the oven.
Could be the hi-limit thermostat (Item 37 in Section 1) is open.
Check it with meter for 0 ohms.
Be sure to kill the power to the un it when doing this.
Be very careful when working on the unit, 240 volts is lethal.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven does not heat after using Cleaning Cycle DoubtingThomas Oven Repair (including Ranges and Cooktops) 3 12-07-2009 07:16 AM
How Do I Start the Self Cleaning Cycle? Roan Oven Repair (including Ranges and Cooktops) 2 05-09-2009 08:52 AM
Thermostat Burns Out on Cleaning Cycle rdsmith2@dow.com Oven Repair (including Ranges and Cooktops) 0 04-27-2009 04:54 PM
Built-inWhirlpool single oven won't heat after cleaning cycle Gail Oven Repair (including Ranges and Cooktops) 1 11-01-2008 12:27 AM
Ice Maker only makes ice during cleaning cycle. LH1 Refrigerator & Freezer Repair 4 07-16-2008 10:52 AM
