Try this again.
I have an oven that when Bake is chosen it immediatly indicates "ON". It will not heat and there are no F codes.
The oven was in use, at one time, set to 325F, after reaching that temp, a cake was placed in the oven. 55 min later, the cake was checked and noticed that the oven indicated 280F. It then operated per above sentence....not heating and indicates it is on and at temp....HA. I would check the existing threads, but 521....I haven't the time to spare.
