| » 4 prong to a 3 prong outlet |
Model Number: kenmore Brand: Kenmore Age: 1 - 5 years
ok so i just purchased this house and i have a 220 outlet for my range that is a 3 prong plug but my range has a 4 prong plug so i bought the wire to make it a 3 prong plug but have no idea how to install it is there a way to make my 220 wire a 4 prong plug without having to break threw the walls? help
Not sure what you mean by "bought the wire". If you mean that you bought a 3 prong power cord for the stove then you are on the right track. but have no idea how to install it is there a way to make my 220 wire a 4 prong plug without having to break threw the walls? Well it can be done but it is against the wiring code so I would not touch the house wiring. Not sure how much you know about electrical so the following is just some basic info. The difference between 4 and 3 prong is: 4 prong, separate Neutral and earth ground (unit's frame) wires. 3 prong, the Neutral and earth ground are the same. The unit's terminal strip is usually 3 connections. The outer 2 are power (L1 and L2) The center is Neutral. Could also be a + configuration see the below link. On the current 4 prong the Black and Red (power)wires go to the outer 2 terminals on the strip. The White (Neutral) goes to the center terminal. The Green (earth ground) is attached to the unit's frame. To covert to 3 prong The Black and Red go to the outer 2 terminals. The White goes to the center terminal but also goes to the unit's frame. Often there is a ground strap in the unit but it will not be connected for 4 prong, you will have to also connect this to the center terminal. NOTE: This is very important because if the frame is not grounded and a live wire touches the frame, the unit's frame/case will be live. Then if you touch the unit and lets say your faucet (usually grounded) you will get a nasty shock. Here is additional info on this. http://www.applianceaid.com/wirehelp.html
__________________
| Display Modes | |
| installing a new 4 prong cord to 3 prong dryer | nmcfay1226 | Dryer Repair | 9 | 02-09-2010 03:23 PM |
| Help changing a 3 prong to a 4 prong (dryer) plug | Micheline | Dryer Repair | 4 | 11-28-2009 08:27 PM |
| 3 prong to 4 prong dryer conversion | chestarse | Dryer Repair | 9 | 11-17-2009 05:04 AM |
| 3 prong to 4 prong ground wire | kevinc | Dryer Repair | 1 | 09-04-2009 12:00 PM |
| Jenn-Air cartridge retro-fit 3 prong/4 prong | vfxmark | Oven Repair (including Ranges and Cooktops) | 0 | 01-02-2008 09:32 AM |
