My issue is that i have been having an issue with my frigidaire wall oven i have been getting f1 error pretty much whenever i cook it usually dosn't happen till when the oven is very hot i hit clear and put it back on and usually 15 minutes later f1 again i read book and book recommended to replace eoc which i did and now i started getting error f10 so my next step is to replace rtd probe which i did get but i have a quick question i see that the part number recommonded for my oven is 316217002 but my friend from work gave me a brand new probe which he never used but the part number is 316217001 will it work for my oven? from looking at the picture the 001 has a shorter wire on it but will i be able to use it? Will the quick connect be the same? I am hoping not too have to pull oven from wall will connector pull out through hole in back of oven? I am hoping to be able to save myself a few bucks any thoughts if the 316217001 will work instead of the 316217002.
Any Thoughts
