| » michael |
Model Number: 911 4132991 Brand: Sears Age: More than 10 years
Double oven - lower oven works fine.
Upper oven has electronic control. Upper oven will not broil or clean. When set to bake at 350 deg, oven will not heat. Setting oven temperature to 550 deg, oven heats. Broil and clean still do not work. I can manually trip the broiler relay to make the broiler element heat. Ohm ckeck of temperature sensor is a few ohms below 1100 ohms specified in spec sheet I found in the oven. Ads By Google Related Models |
| Display Modes | |
| michael | Michael McALonan | Dryer Repair | 0 | 08-11-2009 08:24 AM |
| Michael | pmlshawnee | Garbage Disposer Repair | 0 | 03-31-2009 08:42 AM |
