Discuss
Oven door jammed closed after cleaning - F5EI message
 in
After running the cleaning cycle, the oven door will not open - neither will the drawer. The display area flashes
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven door jammed closed after cleaning - F5EI message
  #1 (permalink)
Old 06-03-2010, 12:57 PM
Junior Member
JK10777 is on a distinguished road
Unhappy Oven door jammed closed after cleaning - F5EI message
Brand: Whirlpool   Age: 5 - 10 years
After running the cleaning cycle, the oven door will not open - neither will the drawer. The display area flashes F5 then E1. I no longer have the manuel so I don't know what this means. Also the model number must be inside the oven or the pot drawer. How do I open the door and drawer?
Thanks for your help.
Ads By Google
  #2 (permalink)
Old 06-03-2010, 04:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It is impossible to identify the oven without correct model number. Try to post some pictures of the oven. It might help.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven door stuck closed twinsrg8 Oven Repair (including Ranges and Cooktops) 0 03-14-2010 01:24 PM
Oven door won't stay closed d07282 Oven Repair (including Ranges and Cooktops) 0 01-11-2010 06:47 AM
Bosch - check door message but door is closed janelfamily Washer Repair 1 01-21-2009 03:05 PM
oven door stuck closed ybbob Oven Repair (including Ranges and Cooktops) 0 12-09-2008 09:21 PM
Oven won't operate with door closed Bixer Oven Repair (including Ranges and Cooktops) 0 11-19-2008 02:02 PM
