Discuss
western holly wall oven 1959 era
 in
My oven door does not close tight. There is a spring and cable at each side. Can someone tell me
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » western holly wall oven 1959 era
  #1 (permalink)
Old 06-01-2010, 08:38 PM
Junior Member
roroble is on a distinguished road
Default western holly wall oven 1959 era
Brand: -other-   Age: More than 10 years
My oven door does not close tight. There is a spring and cable at each side. Can someone tell me how to replace them please?
Ads By Google
  #2 (permalink)
Old 03-20-2012, 07:55 AM
Junior Member
eauctioneer is on a distinguished road
Default I have the same problem
Quote:
Did anyone every get back to you with how to do it? I have all the parts 2 springs and two cables. I just need to know where the cables connect to? If you know can you tell me...
Thank you for your time and help.
eauctioneer
  #3 (permalink)
Old 03-21-2012, 08:35 AM
Junior Member
Default
Received no replies to problem. You will probably need to find a someone to come in. If you're close to 90650, ( Norwalk, Ca.) zip code try GiGi's appliance repair, they work on them. They're located in Southgate,Ca.
562-634-4002, 323-636-7731.
  #4 (permalink)
Old 03-21-2012, 08:53 AM
Junior Member
Default
eauctioneer
No replies. If you're near 90650 zip code, (Norwalk Ca.), try Gigi's in Southgate, Ca. they work on them. 562-634-4002, 323-636-7731.
  #5 (permalink)
Old 03-21-2012, 09:12 AM
Junior Member
Default
Extra: I did see the same oven out of it's cabinet and it was clear where the cables attached to the body. you'd probably have to slide it out about ten inches to see access door attach points.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
western holly wall oven 1959 era roroble Washer Repair 0 06-01-2010 07:48 PM
thermador double wall oven door cable 1959 needhelp Oven Repair (including Ranges and Cooktops) 2 02-29-2008 06:09 AM
1959 (!!) GE wall oven..still works, but... Pamela007 Oven Repair (including Ranges and Cooktops) 0 02-09-2008 07:37 PM
Resurrect 1959 Tappan Model FOK-3100 Wall Ovens (two of them) Jay Parrish Oven Repair (including Ranges and Cooktops) 0 10-11-2007 09:05 PM
