Both simmer burners emit no gas, solenoids check ok, orifices seem clear spark clicker works on all, seems like control unit ($140.00) what do you think?
I have similar problem, spark no gas on just front left burner, others work just fine, Thermador model RDDS30VRS.
So reading all these posts re no gas on XLO burners, it appears that Thermador had an issue and has corrected with the $140 kit containing potentiometers and simmer control unit and these units can't be purchased seperately. Is this correct?
Also, is the piping and wiring accessed by removing the 4 burner venturis and then the top of the range? I would like to run the tests Gene provided before spending the $140....
Shaz, how did u resolve ur front XLO burner on your Thermador, I have the same problem. Millerputnam@gmail.com
Shaz, I have the same problem u had with Thermador XLO burner... What did u do with it?
