Discuss
Whirlpool Double Oven - Upper Not Working
 in
You're welcome. I'm glad you were able to fix it. Gene. Ads By Google
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Double Oven - Upper Not Working
  #31 (permalink)
Old 07-23-2008, 07:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #32 (permalink)
Old 07-26-2008, 02:33 PM
Junior Member
steffco1 is on a distinguished road
Default It's working but making a loud bzing sound
Using to cook it's woring great, bu tmaking a loud noise....Any idea's?
The fan? maybe
  #33 (permalink)
Old 07-26-2008, 02:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Very possible. It can be a bad bearings in the blower motor or a foreign object in the blower wheel. You have to remove the oven and the rear cover to diagnose the fan.
__________________
  #34 (permalink)
Old 08-12-2008, 03:43 PM
Junior Member
TOMF is on a distinguished road
Default
Gene, sorry about the delay. I injured my back and am just now able to tackle this job. Anyway, before I get back in to this, is there a quick solution, even though it might cost more. For example, could I replace the entire control module instead of just the fuse. If so, please provide a part number that I could order. The wife is ready for her oven back !
Thanks.
Tom
  #35 (permalink)
Old 08-12-2008, 03:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Tom,
Replacing the control board should solve this problem with a small chance that something else can be wrong too.
- The part number for the control board is AP3595759
I wish you to get well.
__________________
  #36 (permalink)
Old 08-12-2008, 04:26 PM
Junior Member
Default
Thanks Gene. I think I will go this route. I replaced this exact part almost 2 years ago.
  #37 (permalink)
Old 08-12-2008, 05:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me posted.
__________________
  #38 (permalink)
Old 08-14-2008, 06:04 PM
Junior Member
Default
Gene, I received the replacement part today and the black plastic housing was cracked/chipped in one corner where the ribbon cable enters ... I decided to install anyway ... after installing I powered the unit up and had heat in the top (good news) ... I then checked the bottom and had heat (good news) ... I turned top and bottom on at same time and after a few seconds got a PF code ... unit went thru what appeared to be a power cycle and I tried all of the above again and seemed to work ok ... left it alone ... came back in to kitchen about 45 minutes later and had code E1 F2 ... so I assumed the only chance I had was that the ribbon cable was not plugged in tight ... opened it up and everything looked good ... powered back on, set clock and all appeared ok until I turned the upper oven on and got the E1 F2 code again ... any simple fix?
Thanks Gene,
Tom
  #39 (permalink)
Old 08-15-2008, 01:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Tom,
If you found the part was damaged then you had to return it right away. You can not rely on such part. Call the customer service to exchange the part under the part warranty.
__________________
  #40 (permalink)
Old 08-15-2008, 06:33 PM
Junior Member
Default
OK, I will contact them, but I am considering seeing if they will just accept a return and I will call a repair person to fix the unit. Momma needs her oven!
Thanks for your help.
Tom
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef Double Oven Upper oven not working scri8e Oven Repair (including Ranges and Cooktops) 18 12-30-2012 04:50 PM
Double Oven upper wont work BlueAndGrayElectric Oven Repair (including Ranges and Cooktops) 0 11-23-2009 02:03 PM
Whirlpool double oven quit working - no display jfoscue Oven Repair (including Ranges and Cooktops) 0 06-08-2009 12:46 PM
Whirlpool Double Wall Oven - Top Oven Not Working bigguy Oven Repair (including Ranges and Cooktops) 6 09-18-2008 09:03 AM
Whirlpool double oven upper won't work dwgourley Oven Repair (including Ranges and Cooktops) 0 07-23-2008 04:19 PM
