Discuss
Whirlpool Double Oven - Upper Not Working
 in
Gene, The lower door is locked shut since the power went out. How do I get the door open? Ads
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Double Oven - Upper Not Working
  #11 (permalink)
Old 07-16-2008, 03:39 PM
Junior Member
steffco1 is on a distinguished road
Default
Gene,
Ads By Google
  #12 (permalink)
Old 07-16-2008, 03:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
sreffco1,
Which oven was on self clean when it happened?
Is the display blank?
Did you check the circuit breaker?
I need as much information as possible.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 07-16-2008, 05:46 PM
Junior Member
Default
Gene,
The power cut off it wasn't on self cleaning (the top and the bottom oven) and the screan is blank. I have cut off power to the unit. When I turn the power back on the screan is blank and the oven is locked
  #14 (permalink)
Old 07-16-2008, 08:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Looking through the center vent (#34 on the break down diagram) and on the picture of the door latch bellow
you have to push in the solenoid (the white piece on the bottom of the picture) and move the hook to the side to unlatch the door.
After you open it, check the low voltage transformer (#6 on the break down diagram) and the thermal fuse, plugged into the control board.
__________________
  #15 (permalink)
Old 07-17-2008, 06:32 AM
Junior Member
TOMF is on a distinguished road
Default
Thanks Gene.
I follow you fairly well. But have some questions before I get in to this. Please forgive my ignorance on this.
You say:
"Plug this wire and the red wire from the relay#2 back in place, living the second red wire from the relay#1 out (insulate it)."
How do I insulate it?
Then you say:
"Turn the Bake on the upper oven on and check for 120VAC between the terminal on the relay#1 where the red wire was connected and ground."
Do I use the multimeter for this? If so, red wire from multimeter goes to relay terminal? and black goes to ground? Not sure where ground is? At this point should I get some help? Not real comfortable doing this with the oven on.
Thanks.
  #16 (permalink)
Old 07-17-2008, 12:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Can you post a picture of your multimeter?
__________________
  #17 (permalink)
Old 07-17-2008, 12:43 PM
Junior Member
Default
Gene, here is link to picture ... it is a GE2527
GE Analog Multimeter - Yellow - GE Electrical Wiring Accessories - Jasco Products Company
  #18 (permalink)
Old 07-17-2008, 01:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by TOMF View Post
..."Plug this wire and the red wire from the relay#2 back in place, living the second red wire from the relay#1 out (insulate it)."
1. How do I insulate it?
Then you say:
2. Do I use the multimeter for this? If so, red wire from multimeter goes to relay terminal? and black goes to ground? Not sure where ground is? At this point should I get some help? Not real comfortable doing this with the oven on....
1. Wrap the wire terminal in an insulation tape.
2. Yes, you have to use the multimeter.
Place the control panel in safe position so it sits stable and no electric parts and/or connections are touching each other and/or any body parts.
Switch the multimeter from "Ohm" to "ACV" 250 range what means the full scale is 250VAC. Touch the relay terminal with any one of the probe (does not matter which one) while the other probe is connected to any metal (ground) part of the oven body and read the meter scale.
Post the results.
__________________
  #19 (permalink)
Old 07-17-2008, 05:15 PM
Junior Member
Default
Gene,
I was able to get the oven out and inspected. The heating element in the upper oven was cracked off on one lead, so it appears that it shorted out. I know I need to buy a new element part #7. I have already bought one thermo Fuse, it there any other part that I should check or buy.
Thanks.....
  #20 (permalink)
Old 07-17-2008, 05:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Gene View Post
...After you open it, check the low voltage transformer (#6 on the break down diagram) and the thermal fuse, plugged into the control board...
steffco1,
Did you check these parts?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef Double Oven Upper oven not working scri8e Oven Repair (including Ranges and Cooktops) 18 12-30-2012 04:50 PM
Double Oven upper wont work BlueAndGrayElectric Oven Repair (including Ranges and Cooktops) 0 11-23-2009 02:03 PM
Whirlpool double oven quit working - no display jfoscue Oven Repair (including Ranges and Cooktops) 0 06-08-2009 12:46 PM
Whirlpool Double Wall Oven - Top Oven Not Working bigguy Oven Repair (including Ranges and Cooktops) 6 09-18-2008 09:03 AM
Whirlpool double oven upper won't work dwgourley Oven Repair (including Ranges and Cooktops) 0 07-23-2008 04:19 PM
