Purchased two of the same model Maytag ranges in 2006. Used one from 2007 to 2010. The other used less than one year 2009 to 2010. Both appear to have the same problem. Neither one allows the oven to heat. It appears to be a manufacturers defect, but of course, the warranty has expired. What is the solution to this problem? Thank you
