The oven is turning itself on........It will just come up 350 degrees and say PUSH to Start........you clear it and it comes back.....sometimes if you cut the power off for awile it takes awhile to do it again....we had the control replace about 9 years ago.....the oven will still work....but you must keep the main breaker off until you are ready to use it....any ideas....new contoller needed?..........thank you....terribob
Anyone out there that can help me?....thanx...bump
