| » Jenn air oven heats, but not to correct temp |
Model Number: SVE47600b Brand: Jenn-Air Age: 5 - 10 years
Oven heats up, but if set to 400 degress only heats to 250 degrees. Whe you set it to 450 degrees it only heats to 300 degrees.
Have already replaced the control board and thermostat twice (orders on file from Appliancepartspros.com) with the same condition. Lower heating element also replaced and does heat up (verified). Have tried digital adjustmet to add 30 degrees but that is the limit to adjust. checking actual temperature with two separate digital thermometers. Please assist! |
| Display Modes | |
| Maytag Gemini temp readout not correct | DougW | Oven Repair (including Ranges and Cooktops) | 0 | 05-18-2008 04:54 PM |
| Amana oven not keeping correct temp | jlandwehr | Oven Repair (including Ranges and Cooktops) | 5 | 03-02-2008 04:16 PM |
| Oven not keeping correct Temperature | Andrew Mail | Oven Repair (including Ranges and Cooktops) | 1 | 11-27-2007 04:34 PM |
| Oven lights and heats to Temp but goes out immediately!! | jomo | Oven Repair (including Ranges and Cooktops) | 0 | 08-31-2007 10:49 AM |
| jenn-air cooktop - diagnose correct part | Michael Estep | Oven Repair (including Ranges and Cooktops) | 1 | 08-01-2007 02:18 PM |
