Discuss
Erc Replacement
 in
Just purchased from you replacement part # AP3772915 (made by GE part # WB2T10590). The replacement instructions that came with the part
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Erc Replacement
  #1 (permalink)
Old 07-11-2008, 06:18 PM
demos8121 demos8121 is offline
Junior Member
demos8121 is on a distinguished road
Default Erc Replacement
Model Number: JTP95BW2BB   Brand: GE   Age: 5 - 10 years
Just purchased from you replacement part # AP3772915 (made by GE part # WB2T10590). The replacement instructions that came with the part refer to a 4-pin inline block with black, green, white, and yellow leads and two white SENSOR LEADS.
In step 2: On the models with 9 pin plus 12 pin block harness, disconnect the 4-pin block inside the upper oven (with black, green, white, and yellow leads).
In step 3: On 9 pin plus 12 pin models, it is necessary to cut old sensor connector off at the control and strip the leads for retrofit inside the upper oven control cavity.
In step 6: On 9 pin plus 12 pin models, reconnect the two white SENSOR LEADS with provided wire nuts. No polarity.
Reconnect the 4-pin inline block (with black, green, white, and yellow leads).
Question 1: The 4-pin inline block (with black, green, white, and yellow leads) that came with the new part is a pin connector (male) and it should be a socket connector (female). Is this a mistake or am I suppose to replace the male connector with a female connector? How?
Question 2: In step 6, where do the two white SENSOR LEADS reconnect to? Is it to the old sensor connectors that were cut off and stripped in step 3?
Demos8121
Related Models
General Electric JTP95BW2BB Electric range
General Electric JTP95WA1WW Electric range
General Electric JTP95WA2WW Electric range
General Electric JTP95WA3WW Electric range
General Electric JTP95WA4WW Electric range
General Electric JTP95WA5WW Electric range
General Electric JTP95WA6WW Electric range
General Electric JTP95WD1WW Electric range
General Electric JTP95WW1WW Electric range
General Electric JTP95WW2WW Electric range
Maytag JTRH2 Commercial Cooking
Maytag JTRH2A Commercial Cooking
Maytag JTRH2FHT36 Commercial Cooking
Maytag JTRH36GT36C Commercial Cooking
Maytag JTRH3ST36 Commercial Cooking
Maytag JTRH430 Commercial Cooking
Maytag JTRH436 Commercial Cooking
Maytag JTRH636 Commercial Cooking
Maytag JTRH636C Commercial Cooking
Maytag JTRHE4336C Commercial Cooking
Maytag JTRMB36 Commercial Cooking
Maytag JUB248RBRB00 Beverage Center
Maytag JUB248RBRS00 Beverage Center
Jenn-Air JUC2450ACX Wine Cellar / Under Counter Ref
Jenn-Air JUC2450ARB Wine Cellar / Under Counter Ref
Jenn-Air JUC2450ARS Wine Cellar / Under Counter Ref
Jenn-Air JUC2450ARW Wine Cellar / Under Counter Ref
Whirlpool JUD278DBCX00 Ingredient Center
Maytag JUD278DBCX00 Ingredient Center
Whirlpool JUD278DBES00 Ingredient Center
Maytag JUD278DBES00 Ingredient Center
Maytag JUR248LBCX00 Refrigerator
Maytag JUR248LBEB00 Refrigerator
Maytag JUR248LBES00 Refrigerator
Maytag JUR248RBCX00 Refrigerator
Maytag JUR248RBEB00 Refrigerator
Maytag JUR248RBES00 Refrigerator
Maytag JUW248LBCX00 Wine Cellar
Maytag JUW248LBRB00 Wine Cellar
Maytag JUW248LBRS00 Wine Cellar
Maytag JUW248RBCX00 Wine Cellar
Maytag JUW248RBRB00 Wine Cellar
Maytag JUW248RBRS00 Wine Cellar
Whirlpool JV020000
Whirlpool JV020080
General Electric JV322*01 Electric range
General Electric JV322*02 Electric range
General Electric JV322*03 Electric range
General Electric JV322*J1 Electric range
General Electric JV322*J2 Electric range
General Electric JV322J3 Electric range
General Electric JV322S2 Gas range
General Electric JV322S3AD Range accessory
General Electric JV322S3WH Range accessory
General Electric JV322V1AD Range accessory
General Electric JV322V1WH Range accessory
General Electric JV324*01 Electric range
General Electric JV324*02 Electric range
General Electric JV324*03 Electric range
General Electric JV324*J1 Electric range
General Electric JV324*J2 Electric range
General Electric JV324J3 Electric range
General Electric JV324S1AD Range accessory
General Electric JV324S1WH Range accessory
General Electric JV325S1AA Range accessory
General Electric JV325S1BB Range accessory
General Electric JV325S1WW Range accessory
General Electric JV327X1AD Range accessory
General Electric JV327X1WH Range accessory
General Electric JV332*01 Electric range
General Electric JV332*02 Electric range
General Electric JV332*03 Electric range
General Electric JV332*J1 Electric range
General Electric JV332*J2 Electric range
General Electric JV332J3 Electric range
General Electric JV332S2 Gas range
General Electric JV332S3AD Range accessory
General Electric JV332S3WH Range accessory
General Electric JV332V1AD Range accessory
General Electric JV332V1WH Range accessory
General Electric JV334*01 Electric range
General Electric JV334*02 Electric range
General Electric JV334*03 Electric range
General Electric JV334*J1 Electric range
General Electric JV334*J2 Electric range
General Electric JV334J3 Electric range
General Electric JV334R1 Electric range
General Electric JV334S1 Gas range
General Electric JV335R1 Electric range
General Electric JV335S1AA Range accessory
General Electric JV335S1BB Range accessory
General Electric JV337X1AD Range accessory
General Electric JV337X1CT Range accessory
General Electric JV337X1WH Range accessory
General Electric JV338H1BB Electric range
General Electric JV338H1CC Electric range
General Electric JV338H1WW Electric range
General Electric JV346V1AA Range accessory
General Electric JV346V1BB Range accessory
General Electric JV346V1WW Range accessory
General Electric JV347H1BB Electric range
General Electric JV347H1CC Electric range
General Electric JV347H1WW Electric range
General Electric JV347X1AA Range accessory
General Electric JV347X1BB Range accessory
General Electric JV347X1CC Range accessory
General Electric JV347X1WW Range accessory
General Electric JV348L1SS Electric range
General Electric JV356V2AA Electric range
General Electric JV356V2BB Electric range
General Electric JV356V2WW Electric range
General Electric JV356VAA Range accessory
General Electric JV356VBB Range accessory
General Electric JV356VWW Range accessory
General Electric JV360001 Electric range
General Electric JV367H1BB Electric range
General Electric JV367H1CC Electric range
General Electric JV367H1WW Electric range
General Electric JV374*01 Electric range
General Electric JV376V2BB Electric range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
