My maytag range (mgr5750awd) will beep without any controls being pushed/activated. First noticed problem when oven would not stay on. Unit would beep every so often but was not turning on. Then, after uplugging, plugging back in, it seemed ok, but started beeping randomly in middle of the night. Going to replace the clock (control circuit boards) and hope that solves the problem.
My maytag gas oven keeps beeping. I can't find a model # on it but the control panel looks like the one pictured below. There is no error message, just beeping every few seconds. The clock, burners, and oven all work. Threw the circuit breaker, waited a bit, and turned it back on. Beeping resumed as before, and the clock still displayed the correct time without being reset.
Baffled. Any ideas?
