| » Oven won't bake |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: che9800bcb Brand: Maytag Age: More than 10 years
The top element in the oven only works for broiling. When I bake the bottom element heats up, but the top does not. The food remains raw on top and burned on the bottom. The keypad works fine and tells you when the oven is preheated so it does not detect a problem. Can this be repaired with a part replacement?
Your oven works as designed. The upper (Broil) heating element should work only when the Broil mode is chosen.
Put an oven thermometer in the middle of the oven and measure the temperature while the oven control calls for Bake and set for 350°F. Post the result. Gene.
__________________
Professional appliance repair services in Orange County, California. |
Try to adjust the oven temperature as described on the page 16 in the "Owners manual".
If it would not help then the control board has to be replaced. - The part number for the control board (aka clock) is AP2673398 Here are the break down diagrams for the Maytag range Model CHE9800BCB Gene.
__________________
| Display Modes | |
| Maytag oven won't bake | BestHomes | Oven Repair (including Ranges and Cooktops) | 5 | 01-25-2008 06:46 PM |
| Oven bake element | jas1000 | Oven Repair (including Ranges and Cooktops) | 4 | 12-27-2007 03:03 PM |
| Oven will not bake | sna1imj | Oven Repair (including Ranges and Cooktops) | 3 | 11-12-2007 12:04 PM |
| Oven won't bake, only broil | jae | Oven Repair (including Ranges and Cooktops) | 6 | 11-10-2007 09:22 PM |
| Oven Will Not Bake | tony | Oven Repair (including Ranges and Cooktops) | 6 | 08-01-2007 05:21 PM |
