My oven has no display but i can reset breaker and then press upper oven and start, the lights and blower will come on for a short time and then shut down. I can press all the buttons and they will beep with the exception of the up and down minuet button it will not beep. I have checked all the connections on the control board and they seem to be secure and in good condition. Any help will be greatly appreaciated. Thanks, Wayne
Originally Posted by: Gene Hi Gene, thanks for the quick response i ordered the Control Panel this afternoon. The part will be here on Friday and i will post if the replacement part corrects the problem, Thanks again, Wayne
I seem to have the exact same issue with my whirlpool oven...any word back on whether swapping out the control board solved your problem? Or did the Control Panel work?
