| » KitchenAid Gas Range |
Model Number: KGRT500FWH1 Brand: Kitchen Aid Age: 5 - 10 years
My range oven burner never ignites. All the other burners including the broiler and stove top burners light and work fine. When I turn the oven on, I hear the fan start, the igniter lights up, but I don't hear the gas flowing. When I started troubleshooting, I noticed sometimes when I moved the Valve & Regulator assembly it would sometimes start. I assumed it was a bad Valve & Regulator assembly so I ordered a new one from appliancepartspros and put it in. It is still doing the same thing. Any idea what it could be? Thanks
Most likely the problem is a bad oven igniter.
- The part number for the oven igniter is AP2994573 Here are the break down diagrams for the Kitchen Aid range Model KGRT500FWH1 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
You have to have a special meter to measure current drawn by the igniter. Normally it suppose to be more than 3.2 amps.
__________________
Quote:
If it has 3.2 amps draw then it should be good. But looking at it is the easiest way. If it's white in a certain place or all white. Then it's bad. I would have to say 90% of the calls on gas ranges are Igniters.
__________________
An appliance tech from a small business. Very busy.. But will try to help when possible. |
I just got the igniter in and replaced it. It worked! I'm very impressed with this site and will recommend to my friends. Thanks for your help.
BTW, anyone need a valve and regulator assembly? It looks like it fits multiple models. |
| Display Modes | |
| Kitchenaid ice maker | bryan b | General Talk | 4 | 08-25-2008 01:18 PM |
| Kitchenaid will not dry | mike21 | Dishwasher Repair | 0 | 07-09-2008 01:29 PM |
| KitchenAid electric range burners won't turn on | djfancy | Oven Repair (including Ranges and Cooktops) | 0 | 06-18-2008 09:46 PM |
| kitchenaid range/oven kgst300bwh1 'Err' fault code when over 260 deg | dansanjose | Oven Repair (including Ranges and Cooktops) | 2 | 03-22-2008 03:49 PM |
| Kitchenaid Range Burner will not work | dclarey | Oven Repair (including Ranges and Cooktops) | 1 | 02-19-2008 12:25 PM |
