Discuss
Jenn Air FCE10500W Element Replacement
 in
My element was arcing, so I purchased this replacement. Part Details - MAYTAG Element, part number: 74003019 However, when I received
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn Air FCE10500W Element Replacement
  #1 (permalink)
Old 07-08-2008, 09:21 PM
gostate29 gostate29 is offline
Junior Member
gostate29 is on a distinguished road
Default Jenn Air FCE10500W Element Replacement
Model Number: FCE10500W   Brand: Jenn-Air   Age: 5 - 10 years
However, when I received this replacement the tips are flat. On my existing element, the tips to connect the wires are crimped. Did I get the wrong part, or do I need to attach another way? I've tried getting the wires off the existing bad element to no avail...
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-10-2008, 12:09 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Maytag changed design for this part. You have to replace the existing terminals with push-on female terminals.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Air Hinge Replacement hausfrau Oven Repair (including Ranges and Cooktops) 1 05-15-2008 04:43 PM
Jenn-Air burner control replacement pchip62 Oven Repair (including Ranges and Cooktops) 3 05-10-2008 05:04 PM
Jenn-Air range oven, heating element burnt, clock won't display wuchinguo Oven Repair (including Ranges and Cooktops) 0 04-15-2008 09:41 AM
Element Replacement on Jenn Air Glass Cooktop Alkraut Oven Repair (including Ranges and Cooktops) 2 03-20-2008 06:56 AM
jenn air stove top burner replacement jfh1@bellsouth.net Oven Repair (including Ranges and Cooktops) 1 08-17-2007 09:51 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
