Turned on oven to preheat and the screen went through the preheat process but when I opened the oven it was cold. I tried the Broil also and no heat. Shut the breaker off for 2 minutes then on again, still no heat. Used self-cleaning mode the night before and everything went fine. No visual signs of elements being burned out. If I push Bake and cancel at the same time this code shows up "EO -F0-". What to do next?:confused:
