The right side igniter in my range went bad. I bought a new one but when installing it, I found that the one I bought is for the left hand side. I asked the parts department (Crystal) to check and see if there is a # for a right hand igniter but she said they were the part number. The parts look the same but the mounting is 90 degrees different. This makes the turn-on of the valve not align with the igniter start. Has anyone else run in to this problem? What is the proper part number, or is there a special mounting method?
