Discuss
oven/broiler won't light
 in
my dynasty 48" oven/ broiler will not ignite. when the power is switched on and the common thermostat placed
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven/broiler won't light
  #1 (permalink)
Old 07-08-2008, 11:02 AM
mrides mrides is offline
Junior Member
mrides is on a distinguished road
Default oven/broiler won't light
Model Number: dgr/dgrc   Brand: -other-   Age: More than 10 years
my dynasty 48" oven/ broiler will not ignite. when the power is switched on and the common thermostat placed on a temperature or the broiler setting, both glow bars turn red but no ignition occurs. i replaced the oven gas valve with no change. since both the oven and the broiler quit working at the same time and the ignitors both glow i suspect the problem may be in the thermostat. any suggestions would be appreciated. also, any information regarding a source for dynasty replacement parts would be appreciated. thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-09-2008, 11:57 AM
Junior Member
Default
on a hunch i replaced the oven ignitor. the oven ignited in the normal fashion. i will replace the broiler ignitor soon and hope the entire problem will be resolved.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Oven & Broiler doesn't heat jcreehan Oven Repair (including Ranges and Cooktops) 3 06-16-2008 08:54 AM
Oven & Broiler will not lite leenanme Oven Repair (including Ranges and Cooktops) 0 06-12-2008 11:35 AM
GE Oven and broiler won't light brokenoven Oven Repair (including Ranges and Cooktops) 3 12-06-2007 07:42 PM
oven & broiler won't lite Mike Johnson Oven Repair (including Ranges and Cooktops) 1 11-05-2007 01:13 PM
Broiler will not shut off-With oven off POTENTATE Oven Repair (including Ranges and Cooktops) 1 10-29-2007 06:10 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
