I have a General Electric Wall Oven (30 yrs old) and I am in the process of replacing the broiler element that I received from you. I took the old element out but realized when I got ready to install the new elment that there are 3 wires (two black and one yellow). The element has two tabs with screw holes. The wires have the donut shaped wire connectors (a screw goes through the wire connectors, and then the screw goes into the screw holes on the element). I do not know how to wire it correctly. Can anyone advise as to which wires go where? Thanks!
