Discuss
bake cycle not working but broiler is
 in
30" SLIDE IN GAS RANGE pressing bake, system acknowledges, when attempting to set the temp and pressing ok, the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » bake cycle not working but broiler is
  #1 (permalink)
Old 07-08-2008, 07:18 AM
delta marine delta marine is offline
Junior Member
delta marine is on a distinguished road
Default bake cycle not working but broiler is
Model Number: JGS905SEKSS   Brand: GE   Age: 1 - 5 years
pressing bake, system acknowledges, when attempting to set the temp and pressing ok, the system revirts to 100 degrees only and the system does not ignite.
pressing the broil, system acknowledges, igniter works fine and temp is fine.
bake system is not working.
how do i trouble shoot problem? the lower igniter is under a pan, do i have to take the door off to gain access to this igniter?
thanks
delta marine
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bottom oven broiler not working cavedog Oven Repair (including Ranges and Cooktops) 1 11-23-2008 10:44 AM
Broiler Turns On/ Oven Bake Will Not TRINIDAD Oven Repair (including Ranges and Cooktops) 0 04-26-2008 07:34 AM
oven and broiler not working the stoetop does markk Oven Repair (including Ranges and Cooktops) 1 02-06-2008 04:32 PM
bake glows, not ignite, broiler works fine mydaddy0 Oven Repair (including Ranges and Cooktops) 3 11-28-2007 05:49 PM
Bake Element and BAKE cycle not working jeffman Oven Repair (including Ranges and Cooktops) 1 08-04-2007 11:18 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
