Discuss
Tappan gas range
 in
When we press the bake temp button to turn on the oven the message is "off". Does that
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Tappan gas range
  #1 (permalink)
Old 07-07-2008, 01:42 PM
zakyak zakyak is offline
Junior Member
zakyak is on a distinguished road
Question Tappan gas range
Model Number: 30-4980-32/4   Brand: Tappan   Age: 5 - 10 years
When we press the bake temp button to turn on the oven the message is "off". Does that mean the controls are shot and need to be replaced? An electronic clock control panel for the 30-4980-32/03 looks the same as mine, will it work?
thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-08-2008, 02:12 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad control board (aka clock). Unfortunately this part is no longer available.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tappan Gas Range soulfoniclady Oven Repair (including Ranges and Cooktops) 1 01-01-2008 12:06 PM
Tappan gas range top removal plehan Oven Repair (including Ranges and Cooktops) 0 12-15-2007 03:21 PM
Tappan Range Butch Oven Repair (including Ranges and Cooktops) 0 10-29-2007 06:37 PM
Tappan Gas Range Thermostat Handymen Oven Repair (including Ranges and Cooktops) 0 09-30-2007 02:08 AM
Tappan by Frigidaire Gas range jbonatesta Oven Repair (including Ranges and Cooktops) 1 08-08-2007 05:23 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
