Hi. I have a problem with the display screen on the control panel. The control panel seems to be working fine; I get the confirming tones when pressing the appropriate buttons, but the display is mostly off, i.e. nothing appears on the display at all.
I unplugged the unit to try to reset it and when I plugged it back in, the display came on, but dimly. I pressed a couple of buttons, then cancel and the display on the clock came on all the way, just as normal. About 10 seconds later, it faded to black...
If I need to replace the "Control board - Electronic control assembly with displays (AP3176181)", which I'm not sure I do, but is my only guess, how do I take the unit apart to get to it? maybe something is just lose and taking apart and back together might be all that's needed?
Thanks for any help.
EDIT: Complete Model number is KGRC707LBS0
