| » Simmer Burners Not Working |
Model Number: SGCS304RS Brand: Thermador Age: 5 - 10 years
One XLO Simmer Burner failed to operate. Exchanging the potentiometers moved the problem to the other XLO burner indicating a bad potentiometer. Opening the failed potentiometer revealed an open in the switch circuit trace. I installed the new Bosch/Thermador kit with the new potentiometers and simmer control module. Now neither XLO burner will work - no indicator light, no solenoid valve operation, no ignition spark, etc. The ignition control module works fine when operating the two other standard burners. It creates spark at all four burners just fine. The wiring has been checked as during the exchnage of modules I only moved one connector at a time to the new module. Both solenoid valves have been checked with a VOM and indicate the proper resistance.
What should I suspect and/or check next? Last edited by Schwing : 07-07-2008 at 11:02 AM. Reason: Removed icon from middle of text |
| Display Modes | |
| Thermador Simmer Burners Not Working | jstarzy | Oven Repair (including Ranges and Cooktops) | 1 | 05-20-2008 10:36 AM |
| Right burners not working | Shrimpkin | Oven Repair (including Ranges and Cooktops) | 0 | 02-08-2008 02:19 PM |
| Range burners all stopped working | andynanneda | Oven Repair (including Ranges and Cooktops) | 0 | 01-18-2008 05:38 AM |
| Oven not working but burners are | Andre | Oven Repair (including Ranges and Cooktops) | 0 | 12-30-2007 09:54 AM |
| gas range burners not working properly | Larry216 | Oven Repair (including Ranges and Cooktops) | 1 | 12-10-2007 12:00 PM |
