Discuss
Touch pad ?
 in
Jenn Air W131W SN 13512466HZ installed Feb 1994 Started getting intermittent F7 error code several years ago. January this year
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Touch pad ?
  #1 (permalink)
Old 07-07-2008, 10:33 AM
maxflied maxflied is offline
Junior Member
maxflied is on a distinguished road
Unhappy Touch pad ?
Model Number: W131W   Brand: Jenn-Air   Age: More than 10 years
Jenn Air W131W SN 13512466HZ installed Feb 1994 Started getting intermittent F7 error code several years ago. January this year went to a more persistant F1, A few weeks ago we got a constant F0 code and had to shut the breaker off. Wasn't able to use oven at all. I have disconnected all terminals and reconnected. After removing the temp sensor and checking resistance, 1.112K at room temp to 1.2xx at hot water temps ( around 130 degrees ) and replacing, and powering up with ribbon to the touchpad disconnected, and reconnected I don't get the error codes but the fan stays on constant and oven/broiler do not heat at all. Both limits ( top and rear ) show continuity ( closed? ) at room temps, zero resistance. Broiler/bake elements show 18ohms/20.6 ohms respectively. Have 120 in both legs in. 120 at bake and broiler elements both sides black and red regardless of the control being on or off. In summary my oven will not heat and the fan runs continuous while power is on. I would like to just replace the touchpad but would like some reassurance. Thank you
Related Models
Jenn-Air W131W Walloven - S/c Ele
Jenn-Air W131W-C Walloven - S/c Ele
Jenn-Air W132B Walloven - S/c Ele
Jenn-Air W132W Walloven - S/c Ele
Jenn-Air W136 Walloven - S/c Ele
Jenn-Air W136-C Walloven - S/c Ele
Jenn-Air W136W Walloven - S/c Ele
Jenn-Air W136W-C Walloven - S/c Ele
Jenn-Air W140 Walloven - S/c Ele
Jenn-Air W141 Walloven - S/c Ele
Jenn-Air W141-C Walloven - S/c Ele
Jenn-Air W142 Walloven - S/c Ele
Jenn-Air W142-C Walloven - S/c Ele
Jenn-Air W146 Walloven - S/c Ele
Jenn-Air W146-C Walloven - S/c Ele
Magic Chef W14EA1 Washer - Top Loading
Magic Chef W14EN1 Washer - Top Loading
Magic Chef W14EY1 Washer - Top Loading
Magic Chef W14HA1 Washer - Top Loading
Magic Chef W14HN1 Washer - Top Loading
Magic Chef W14HY1 Washer - Top Loading
Magic Chef W14JA1 Washer - Top Loading
Magic Chef W14JN1 Washer - Top Loading
Magic Chef W14JY1 Washer - Top Loading
Jenn-Air W156 Walloven - S/c Ele
Jenn-Air W156-C Walloven - S/c Ele
Jenn-Air W156B Walloven - S/c Ele
Jenn-Air W156B-C Walloven - S/c Ele
Jenn-Air W156W Walloven - S/c Ele
Jenn-Air W156W-C Walloven - S/c Ele
Jenn-Air W181 Walloven - S/c Ele
Jenn-Air W188 Walloven - S/c Ele
Jenn-Air W188-C Walloven - S/c Ele
Jenn-Air W188W Walloven - S/c Ele
Jenn-Air W188W-C Walloven - S/c Ele
Amana W18C3HES Room Air Conditioner
Magic Chef W18DA2 Washer - Top Loading
Magic Chef W18DN2 Washer - Top Loading
Magic Chef W18DY2 Washer - Top Loading
Magic Chef W18EA1 Washer - Top Loading
Magic Chef W18EA2 Washer - Top Loading
Magic Chef W18EN1 Washer - Top Loading
Magic Chef W18EN2 Washer - Top Loading
Magic Chef W18EY1 Washer - Top Loading
Magic Chef W18EY2 Washer - Top Loading
Magic Chef W18FA1 Washer - Top Loading
Magic Chef W18FA1C Washer - Top Loading
Magic Chef W18FA2 Washer - Top Loading
Magic Chef W18FN1 Washer - Top Loading
Magic Chef W18FN1C Washer - Top Loading
Magic Chef W18FN2 Washer - Top Loading
Magic Chef W18FY1 Washer - Top Loading
Magic Chef W18FY1C Washer - Top Loading
Magic Chef W18FY2 Washer - Top Loading
Magic Chef W18GA1 Washer - Top Loading
Magic Chef W18GN1 Washer - Top Loading
Magic Chef W18GY1 Washer - Top Loading
Magic Chef W18HA1 Washer - Top Loading
Magic Chef W18HN1 Washer - Top Loading
Magic Chef W18HY1 Washer - Top Loading
Magic Chef W18JA1 Washer - Top Loading
Magic Chef W18JN1 Washer - Top Loading
Magic Chef W18JY1 Washer - Top Loading
Jenn-Air W198 Walloven - S/c Ele
Jenn-Air W198-C Walloven - S/c Ele
Jenn-Air W198W Walloven - S/c Ele
Jenn-Air W198W-C Walloven - S/c Ele
Jenn-Air W200 Walloven - S/c Mwave Ele
Jenn-Air W204 Walloven - S/c Mwave Ele
Magic Chef W204KA Washer - Top Loading
Magic Chef W204KV Washer - Top Loading
Magic Chef W204KW Washer - Top Loading
Jenn-Air W205 Walloven - S/c Mwave Ele
Magic Chef W205KA Washer - Top Loading
Magic Chef W205KAC Washer - Top Loading
Magic Chef W205KGA Washer - Top Loading
Magic Chef W205KGV Washer - Top Loading
Magic Chef W205KGW Washer - Top Loading
Magic Chef W205KV Washer - Top Loading
Magic Chef W205KW Washer - Top Loading
Magic Chef W205KWC Washer - Top Loading
Jenn-Air W206B Walloven - S/c Ele
Jenn-Air W206B-C Walloven - S/c Ele
Magic Chef W206KA Washer - Top Loading
Magic Chef W206KV Washer - Top Loading
Magic Chef W206KW Washer - Top Loading
Jenn-Air W206W Walloven - S/c Ele
Jenn-Air W206W-C Walloven - S/c Ele
Magic Chef W207KA Washer - Top Loading
Magic Chef W207KAC Washer - Top Loading
Magic Chef W207KKW Washer - Top Loading
Magic Chef W207KV Washer - Top Loading
Magic Chef W207KW Washer - Top Loading
Magic Chef W207KWC Washer - Top Loading
Magic Chef W208KA Washer - Top Loading
Magic Chef W208KV Washer - Top Loading
Magic Chef W208KW Washer - Top Loading
Magic Chef W209KA Washer - Top Loading
Magic Chef W209KAC Washer - Top Loading
Magic Chef W209KV Washer - Top Loading
Magic Chef W209KVC Washer - Top Loading
Magic Chef W209KWA Washer - Top Loading
Magic Chef W20DA3 Washer - Top Loading
Magic Chef W20DA4 Washer - Top Loading
Magic Chef W20DN3 Washer - Top Loading
Magic Chef W20DN4 Washer - Top Loading
Magic Chef W20DY3 Washer - Top Loading
Magic Chef W20DY4 Washer - Top Loading
Magic Chef W20EA2 Washer - Top Loading
Magic Chef W20EA3 Washer - Top Loading
Magic Chef W20EA4 Washer - Top Loading
Magic Chef W20EN2 Washer - Top Loading
Magic Chef W20EN3 Washer - Top Loading
Magic Chef W20EN4 Washer - Top Loading
Magic Chef W20EY2 Washer - Top Loading
Magic Chef W20EY3 Washer - Top Loading
Magic Chef W20EY4 Washer - Top Loading
Magic Chef W20FA2 Washer - Top Loading
Magic Chef W20FA2C Washer - Top Loading
Magic Chef W20FA3 Washer - Top Loading
  #2 (permalink)
Old 07-08-2008, 04:14 PM
Junior Member
Default
With all the problems these ovens seem to have, is it worth repairing or better to just replace!! Hope to find out soon.
  #3 (permalink)
Old 07-09-2008, 02:17 PM
Junior Member
Default
Quote:
Any help appreciated!!
  #4 (permalink)
Old 07-09-2008, 04:57 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
If you did not get the error codes with the touch pad ribbon disconnected then the problem is a bad touch pad and a new one should fix it.
It's hard to say if it's worth to fix it because of age of the oven.
- The part number for the control panel is AP2666216
__________________
  #5 (permalink)
Old 07-13-2008, 08:38 AM
Junior Member
Default
Thank you Gene, I have ordered that part and should get it tommorrow. Took a while to find your reply because I kept going back to my original saved page to desktop, my bad. Thanks again, max
  #6 (permalink)
Old 07-14-2008, 07:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Max,
Keep us posted.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Touch pad not illuminated robert22 Oven Repair (including Ranges and Cooktops) 16 01-06-2009 03:40 PM
Dryer Hot to Touch Simba Dryer Repair 1 03-30-2008 04:39 PM
computer touch pad is acting up wendypyle@sbcglobal.net Microwave Repair 0 03-25-2008 11:43 AM
Erc Board/touch Pad sampy Oven Repair (including Ranges and Cooktops) 2 02-23-2008 04:07 AM
Microwave Touch Screen vbivans Microwave Repair 1 08-10-2007 04:12 PM
