When I cooked beakfast oven worked fine, when I put roast in oven to cook it glowed orange but burner did not come on. tried to turn on broiler & set it on hi, clock came back on which it does not when broiling
Originally Posted by: trapperone When I cooked beakfast oven worked fine, when I put roast in oven to cook it glowed orange but burner did not come on. tried to turn on broiler & set it on hi, clock came back on which it does not when broiling The ignitor coil is bad. That is the part that glows. It is not glowing bright enough to open ther gas valve. Replace it, and you will fresh biscuits in the morning. Tom ApplianceEducator.com - Parts
