| » Viking range |
Model Number: VGIC3054BSS Brand: -other- Age: 1 - 5 years
New to this , 1st my convection system stopped working in the oven which we just didnt use until we fixed it and now less than 2 weeks later the oven does not heat up at all . Can smell gas yet no heat . Everything else seems fine . Four burners on top all work properly . Any suggestions where to start?
Quote:
It could be the Igniter that is not working. I replace many for all makes of ranges. It's the most common part for ovens not working on gas ranges. |
I took out the bottom pan and see two burners and two igniters(assuming the igniters are the two that glow next to the burners)Its seems that the igniters are fine . They stay lit . The two burners go on seperately shortly aftger but it seems that the one burner goes out after not even a minute. Could it be the gas valve ? Are there seperate gas valves for each burner on the bottom ? If not ????? Thank you for your advice and time on this matter.
The glow bar can glow, but if it does not reach and stay between 3.2-3.7 amps it needs replacing. You can put an ampprobe on one of the wires from the glow bar to measure this, or you could take a resistance reading of the glowbar. Resistance should be between 50-150ohms. If it is not within this the glowbar is bad and needs replacing.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
| Display Modes | |
| stop the sparks Viking Gas cook top | Tommy T. | Oven Repair (including Ranges and Cooktops) | 4 | 11-23-2008 01:14 PM |
| Viking dishwasher | willowbank | Dishwasher Repair | 2 | 01-24-2008 11:03 AM |
| Viking cooktop ignitors supply? | slednerd | Oven Repair (including Ranges and Cooktops) | 1 | 01-22-2008 12:55 AM |
| viking dryer squeels | ryanp | Dryer Repair | 1 | 01-16-2008 08:43 PM |
| Viking gas cooktop disassembly? | slednerd | Oven Repair (including Ranges and Cooktops) | 1 | 11-12-2007 11:58 AM |
