My entire oven is turning off seemingly at random when baking using the top oven. The entire unit turns off and the screen goes blank. Usually within a minute to a few minutes it will turn back on and it usually recalls the time and other oven settings but it has begun to seemingly reset (oven temeperature and cook settings are lost and time is flashing).
A possibly related problem is that the digital clock seems to be slow by a several minutes constantly. If I set the time, it is usually late by a few minutes within a couple of days.
I have never had to reset a breaker and there doesn not seem to be a disturbance in the electric current in the rest of the house (such as a brief dim in the lights) that coincides with the unit turning off.
Any ideas? Do I have a bad controller?
