Discuss
Gas oven slow to lite
 in
My propane oven is slow to lite. I put a meter on the igniter and got 3.5 amps, within
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas oven slow to lite
  #1 (permalink)
Old 09-07-2007, 01:41 PM
Rayman Rayman is offline
Junior Member
Rayman is on a distinguished road
Default Gas oven slow to lite
Model Number: SF310PEYN0   Brand: Whirlpool   Age: More than 10 years
within the 3.2-3.6 range. Ok, while making this test the burner came on but the
flame was weak then there was a click from the bottom of the oven and the flame became full. I turned it off then on again and had to wait another 30 sec.
or so but it lit to a full flame. Oh yeah theres a slight whistling sound just as the burner comes on. So maybe a bad oven safety valve? How do you check it?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-12-2007, 11:26 AM
lfd39 lfd39 is offline
Junior Member
lfd39 is on a distinguished road
Default
I'm having a similar problem with my amana stet he temp and the ignighter will energize but the valve wont open for several minutes I replaced the valve with no change and I was wondering if it's the ballast there is a ballast in the lower part of the oven if that is the power for the valve it may not be giving it the proper power to open the valve??
  #3 (permalink)
Old 09-12-2007, 10:54 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Rayman
Did you have such problems with the top burners?
If your answer is "yes" then the problem is a bad pressure regulator.
If "no" then most likely the problem is a bad gas safety valve (#10 on the oven burner parts break down diagram).
- The part number for the new gas safety valve AP3119546
- Here are the break down diagrams for the Whirlpool range Model SF310PEYN0
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #4 (permalink)
Old 09-12-2007, 10:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi lfd39
Post the model number, please.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
icemaker working slow smiley General Talk 3 06-11-2008 12:41 PM
Washer is slow to fill Dbowls Washer Repair 1 08-30-2007 03:22 PM
Cooktop lite Stu Mills Microwave Repair 0 08-24-2007 12:23 PM
Dryer Dries To Slow Javier Dryer Repair 2 08-21-2007 07:35 PM
ice maker works but slow jeffrey Refrigerator & Freezer Repair 1 08-10-2007 11:02 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
