njbiggs2244
#1 Posted : Saturday, May 15, 2010 3:08:59 PM(UTC)
njbiggs2244
On the key pad, the following numbers - 1-2-3-4-5-6 no longer work. numbers 7-8-9 and back-0-enter are working. This means that I cannot set the clock or the timer. I also cannot set the oven temperature for anything except 350 and 375. Any ideas?
#2 Posted : Monday, May 17, 2010 4:18:28 AM(UTC)
Replacement parts for JENN-AIR JGS9900BDB Range - S/c S/i Ddraft Gas | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag_library/docs/16026925.pdf
Here is manual
http://www.servicematters.com/maytag_library/docs/16026923.pdf
The non working keys you list all use track 2 as a common, problem ios so does "0" and you said this is OK.
The problem could be the control panel or the control board.
Check the control panel (keypad) with a meter
If it checks out OK then it is probably your control board.
Still a bit of a crap shoot but your odds are better.
Try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
ventivent
#3 Posted : Wednesday, April 6, 2011 4:20:39 PM(UTC)
ventivent
I'm having the EXACT same problem with the same model. OP, if you're still around how did you ultimately solve this? Did you have to get a new keypad?
