I have a old RCA gas range the oven pilot lights but the oven will not work. If I search for the model number L2D1156PL2WH no results are found. I understand that GE aquired RCA's ranges and other products in the mid 1980's.
Anyway, I believe the thermo coupler on the oven needs to be replaced. Does GE/RCA make a replacement thermo coupler for the model I listed above or is there an aftermarket universal thermocoupler available for purchase somewhere?
