Discuss
Clock timer problem
 in
After a recent power failure, I went to reset the clock on my Frigidaire smooth top range, model # GLEF369DBA. After
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Clock timer problem
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-05-2008, 09:24 AM
DBall6365 DBall6365 is offline
Junior Member
DBall6365 is on a distinguished road
Smile Clock timer problem
Model Number: GLEF369DBA   Brand: Frigidaire   Age: 1 - 5 years
After a recent power failure, I went to reset the clock on my Frigidaire smooth top range, model # GLEF369DBA. After setting the clock to the correct time, and hitting start, the display went dark after 5 seconds and the time did not show anymore. I tried it several more times with the same result. The display area is now always blank until you go to bake something in the oven or use the timer feature. Then the area lights up as it should. All other features of the range work correctly, including timer, oven temps, etc. Can you advise what part has failed??
Thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Clock/timer olefin32 Oven Repair (including Ranges and Cooktops) 4 06-19-2008 06:36 PM
Frigidaire Gas oven Clock/timer Replacement ChuckH Oven Repair (including Ranges and Cooktops) 7 02-28-2008 07:52 PM
no error codes; is Clock/Timer EOC the problem? 2132mg Oven Repair (including Ranges and Cooktops) 1 02-12-2008 11:51 AM
Does GE JKP54GOV have seperate clock and timer unit bethgsimm Oven Repair (including Ranges and Cooktops) 3 01-20-2008 10:31 AM
Oven clock, timer, display is blank. dorannj Oven Repair (including Ranges and Cooktops) 0 09-12-2007 08:17 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
