peterg7
#1 Posted : Saturday, May 15, 2010 7:32:53 AM(UTC)
peterg7
I had the heating element rupture and short in the upper oven. I ordered the replacement heating element and installed it. After an hour with the oven on, the oven temp only reaches 225 degrees when set to 450 degrees. Is the new heating element bad or is there something else that I should check?
Oven Heating Element Wire Repair (Oven Repair (including Ranges and Cooktops))
by JT5 11/22/2023 5:20:00 AM(UTC)
old Wall oven heating element problems (Oven Repair (including Ranges and Cooktops))
by shelliejh 12/6/2018 12:16:51 PM(UTC)
Need oven heating element GE # J320B1AV (Oven Repair (including Ranges and Cooktops))
by railfan777 10/18/2017 12:48:58 PM(UTC)
Lower oven heating element does not heat up (Oven Repair (including Ranges and Cooktops))
by msterren 4/16/2016 8:45:48 AM(UTC)
Oven Heating Element Won't Turn Off (Oven Repair (including Ranges and Cooktops))
by this_is_nascar 10/4/2014 1:38:26 PM(UTC)
Replacing hotpoint oven heating element (Oven Repair (including Ranges and Cooktops))
by billsee 11/29/2013 6:37:57 AM(UTC)
Need help with range digital display after replacing oven heating element (Oven Repair (including Ranges and Cooktops))
by brewbaker 12/27/2012 3:11:57 PM(UTC)
new oven heating element will not heat (Oven Repair (including Ranges and Cooktops))
by Johnwg 7/15/2012 1:08:39 PM(UTC)
oven heating element popped (Oven Repair (including Ranges and Cooktops))
by howie b. 6/25/2012 3:26:59 PM(UTC)
Oven heating element (Oven Repair (including Ranges and Cooktops))
by snap683 3/15/2012 4:24:26 PM(UTC)
Oven Heating Element Split In Half! (Oven Repair (including Ranges and Cooktops))
by marinakiser 12/10/2011 4:36:11 PM(UTC)
G.E. oven heating element installation (Oven Repair (including Ranges and Cooktops))
by gloria Oliphant 10/24/2011 10:58:44 AM(UTC)
Oven Heating Element Cracked (Oven Repair (including Ranges and Cooktops))
by clramey 7/11/2011 3:00:12 PM(UTC)
Oven heating elements do not work (Oven Repair (including Ranges and Cooktops))
by Packy62 2/23/2011 8:57:48 AM(UTC)
How to replace oven heating element? (Oven Repair (including Ranges and Cooktops))
by ssananikone 1/7/2011 7:49:00 PM(UTC)
