Oven does not reach setpoint temperature. When control panel is set for 300, I measure 275. When set for 400, measure 325. When set for 450, measure 360. Removed Temp Probe, measure 1080 ohm at room temp (75F), and measure 1333 ohm in boiling water (212F). Is this enough data to conclude where the problem is, and what to replace?
