Discuss
Jen-Air Cycling on Off in Clean Mode + Clock
 in
Clock Display Began to Fade after 2 years. A year later the oven started to randomly go into clean mode
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jen-Air Cycling on Off in Clean Mode + Clock
  #1 (permalink)
Old 07-03-2008, 11:40 AM
toddmccracken toddmccracken is offline
Junior Member
toddmccracken is on a distinguished road
Default Jen-Air Cycling on Off in Clean Mode + Clock
Model Number: JMW8527CAW   Brand: Jenn-Air   Age: 1 - 5 years
Clock Display Began to Fade after 2 years. A year later the oven started to randomly go into clean mode and other cycles - You could control unit but required pressing buttons several times. Unit clicked and made various noises. Unit slowly started to lose functions and then regain them. Bake etc. Removed clock from housing noticed that upper right corner of LED was burnt looks like it had internal short. While troubleshooting dropped control panel on hard floor now I get constant beep code. Disconnected clock cable to touch panel still getting beep code. Looks like I should try to replace first with AP369030 if that does not get it then AP378776. Anyother suggestions
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cycling problem McGrath Dryer Repair 0 05-02-2008 08:53 AM
Compressor cycling kuperrr Refrigerator & Freezer Repair 2 04-15-2008 04:58 AM
Washer not cycling sam_rosales Washer Repair 0 01-25-2008 01:50 PM
F1 failure code in self clean mode only scruffydog Oven Repair (including Ranges and Cooktops) 10 12-27-2007 12:24 PM
Oven cycling on and off. LeeTBaker Oven Repair (including Ranges and Cooktops) 0 12-01-2007 08:33 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
