Discuss
Broiler element won't work
 in
We have a Kitchenaid Superba Convection whose broiler element doesn't heat up. I replaced the element before going through
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Broiler element won't work
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-02-2008, 02:54 PM
kelrey kelrey is offline
Junior Member
kelrey is on a distinguished road
Default Broiler element won't work
Model Number: KERC507HBT3   Brand: Kitchen Aid   Age: 5 - 10 years
I replaced the element before going through the proper checks so I am pretty that isn't the issue. Their continuity is good as well.
I also checked the continuity to both inner and outer wires and they also seem good.
When the oven is on both inner and outer elements check 120v at both ends of the contacts but, no heat.
Is there a way to check the control panel to insure I am replacing the right part?
Is there a thermal fuse and if so could that be the problem? (we do live in Iowa and have had a "few" thunder storms lately) I saw mention of a thermal fuse on Whirlpool and Kitchenaid but have found none nor reference of one for this model.
Hope you can help and thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Broiler won't work Victor Oven Repair (including Ranges and Cooktops) 0 05-06-2008 09:34 AM
Installing Broiler Element punliner Oven Repair (including Ranges and Cooktops) 0 04-05-2008 06:00 PM
SVD48600W broiler doesn't work BarnDreams Oven Repair (including Ranges and Cooktops) 1 03-17-2008 06:54 PM
Broiler Element Not Heating Rbrookler Oven Repair (including Ranges and Cooktops) 0 12-29-2007 03:27 PM
Broiler Element david323 Oven Repair (including Ranges and Cooktops) 1 11-23-2007 11:30 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
