Discuss
No gas to bake burner
 in
Broil works fine - igniter healthy glow, gas supplied, lights fine Bake has been erratic. Took off heat cover to observe.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » No gas to bake burner
  #1 (permalink)
Old 07-02-2008, 12:49 PM
Specker Specker is offline
Junior Member
Specker is on a distinguished road
Default No gas to bake burner
Model Number: ARG7600WW   Brand: Amana   Age: 5 - 10 years
Bake has been erratic. Took off heat cover to observe. Igniter glows strongly, gas doesn't seem to show, no lighting, no bake.
Ideas?
Thanks!
Related Models
Amana ARG7600WW Range - S/c S/i Ddraft Gas
Amana ARG7800CC Range - S/c S/i Ddraft Gas
Amana ARG7800E Range - S/c S/i Ddraft Gas
Amana ARG7800LL Range - S/c S/i Ddraft Gas
Amana ARG7800SS Range - S/c S/i Ddraft Gas
Amana ARG7800WW Range - S/c S/i Ddraft Gas
Amana ARGS7650CC Range - S/c S/i Ddraft Gas
Amana ARGS7650E Range - S/c S/i Ddraft Gas
Amana ARGS7650LL Range - S/c S/i Gas
Amana ARGS7650SS Range - S/c S/i Gas
Amana ARGS7650WW Range - S/c S/i Gas
Amana ARH660 Range - S/c S/i Ddraft Gas
Amana ARH660HR Range - S/c S/i Ddraft Ele
Amana ARH664E Range - S/c S/i Ddraft Ele
Amana ARH664WW Range - S/c S/i Ddraft Ele
Amana ARH665E Range - S/c S/i Ddraft Ele
Amana ARH665WW Range - S/c S/i Ddraft Ele
Amana ARH667E Range - S/c F/s Ele
Amana ARH667WW Range - S/c S/i Ddraft Ele
Amana ARH6700E Range - S/c S/i Ddraft Gas
Amana ARH6700LL Range - S/c S/i Ddraft Gas
Amana ARH6700WW Range - S/c S/i Ddraft Gas
Amana ARH6710E Range - S/c S/i Ddraft Gas
Amana ARH6710LL Range - S/c S/i Ddraft Gas
Amana ARH6710WW Range - S/c S/i Ddraft Gas
Amana ARHC7700E Range - S/c S/i Ddraft Ele
  #2 (permalink)
Old 07-02-2008, 11:43 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Take a resistance reading of the ignitor, should be between 50-150ohms, if not in this range, replace the ignitor. If you have an ampprobe, you cann take an amp reading of the ignitor when glowing, should be about 3.2-3.7 amps, if not, replace ignitor....Post results
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 07-03-2008, 10:32 AM
Junior Member
Default Oven fixed!
Replaced the bake ignitor without test via ohmeter. It just seemed to be the problem, and I didn't have the meter. Ran down to the appliance repair place for the part, put it in, and the unit works like new.
Thanks to all for the assistance.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bake burner won't ignite untamedspirit Oven Repair (including Ranges and Cooktops) 10 06-18-2008 05:36 PM
bAKE Beverly12 Oven Repair (including Ranges and Cooktops) 0 05-14-2008 11:18 AM
No gas to bake burner untamedspirit Oven Repair (including Ranges and Cooktops) 0 04-27-2008 04:52 PM
I can`t bake john d Oven Repair (including Ranges and Cooktops) 0 04-05-2008 06:39 AM
Bake Element and BAKE cycle not working jeffman Oven Repair (including Ranges and Cooktops) 1 08-04-2007 11:18 PM
