Received part number GEH WB27X10311 DESCRIPTION: TO8C CONTROL
New part shows Black Line Voltage wire Old part has Red wire. I assume these are the same and I should plug my Red wire where the directions on the new part show Black wire hook up.
Second, New part shows use of a jumper on two terminals or " terminal blocks installed (not used). Do I need a jumper or do I leave these to terminal alone?
