| » jenn air touch panel? |
Model Number: jda8850aas Brand: Jenn-Air Age: 5 - 10 years
My Jenn Air dual fuel stove started flashing F1-8 and then beeping. If we turned the power off over night we could use the oven for a few hours the next day. Then it would repeat the code and beeping. After a few weeks the over night was not enough to reboot and the oven just flashed code and beeped. Was told I needed the circuit board (also referred to as clock and harness) replaced. I orded part #74009315 from your site. My repair guy put in the new part and the same code came up. He says it must be the touch panel, part #74007239. I am curious if this sounds correct. Would love a reply.
Here is a manual.
I am not sure if it applies to your unit as I cannot find any info on that model number. http://www.servicematters.com/maytag...s/16010161.pdf Looks like the error may be a bad temperature probe (sensor) Here is a good site with basic info http://www.applianceaid.com/elecrange.html Check out 7, 8 20 and 21
__________________
| Display Modes | |
| Jenn-Air start light not turning on, touch panel or control board? | Jennairfrustrated | Dishwasher Repair | 9 | 08-08-2010 07:26 AM |
| touch pad Jenn Air | luv2bake | Oven Repair (including Ranges and Cooktops) | 7 | 11-01-2009 08:21 AM |
| Jenn-Air range ERC versus touch pad | rduncan478 | Dishwasher Repair | 1 | 01-16-2009 11:29 AM |
| Jenn-Air touch pad versus clock | rduncan478 | Oven Repair (including Ranges and Cooktops) | 0 | 01-16-2009 11:20 AM |
| Jenn Air Touch PAd | steve67 | Oven Repair (including Ranges and Cooktops) | 3 | 11-05-2008 07:28 PM |
